It is currently Sun Jul 27, 2025 9:38 pm
 Post subject: question about ebonizing
PostPosted: Tue Mar 30, 2021 8:31 am
ebonizing... ebonization ? ha
I want to ebonize my next hog neck on build 22! I have a grasp on how to create the ebonization fluid (doesn't that sound cool), but in thinking through it I'm a little confused on HOW to apply it.
At what point in the finishing process do I ebonize the wood? If it raises the grain, I'll need to sand back. Won't that create a light area?
Thanks.
b
PostPosted: Tue Mar 30, 2021 8:36 am
Rais the grain with water first then sand back. Should probably repeat. Then stain it. You can simply use a cloth or one of those foam brushes to apply the stain, err I mean ebonization fluid.
PostPosted: Tue Mar 30, 2021 8:44 am
so just raise the grain to sand as usual, then apply the ebonization fluid... and continue the process of finishing :)
I think this is going to look great with my wenge back and sides!
These users thanked the author SnowManSnow for the post: RMJ (Tue Mar 30, 2021 1:17 pm)
PostPosted: Tue Mar 30, 2021 9:20 am
Online
Last Name: Colbert
City: Anacortes
Yup, Warm water to raise the grain, lightly sand back, apply very strong black tea (adds tannins. 4 bags in 1 cup of boiling water), then apply the iron sauce. I apply with a foam brush (doesn’t take much. Dip a corner and go) letting each coat dry before moving to the next. I like to do two passes. Let dry for 24hrs then apply two coats of Silvertip with a foam brush, then sand level, adding more as needed. I do not sand between the coats of Silvertip. I think it says there is no need to sand between coats as long as you redcoat within 72hrs. Read the label.
It’s really easy and it looks cool!
M
PostPosted: Tue Mar 30, 2021 11:34 am
M
The tea is a new one didn’t know that
PostPosted: Tue Mar 30, 2021 12:00 pm
Online
Last Name: Colbert
City: Anacortes
M
Handy for ebonizing woods with low natural tannin content. I use the tea on everything cuz I want the color to be as dark as possible.
M
These users thanked the author Michaeldc for the post: SnowManSnow (Tue Mar 30, 2021 10:19 pm)
PostPosted: Tue Mar 30, 2021 2:10 pm
Unless you want to DIY, dye for leather will do a great job. Fiebings is what a lot of people (and pro shops) use to make ebony bridges and fingerboards jet-black.
Brent
PostPosted: Wed Mar 31, 2021 10:38 am
First name: mike
Last Name: mcgrail
State: ky
Black Tea! I have to try this. maybe it will help this white persimmon wood.
Many thanks
PostPosted: Thu Apr 01, 2021 6:43 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Ebonizing looks great, if the timber has sufficient tannin content to react well. The black tea trick adds a bit more tannin and might improve the result. But some timbers just won’t react with the iron. Then the black leather dye is your best bet. As always, test on scrap first. In this one the neck timber is australian blackwood, the same as the body. It ebonizes really well.
Users browsing this forum: Michaeldc and 21 guests
